I went though a couple of for sale ads and compiled a master list of all things one might need to address when buying an E30.
A subset of this list could be used as a checklist to give a PPI mechanic.
Or, it may be used as a guide to assist in prioritization of DIY projects.
To that end, is there any way you guys can comment on the list?
TYPICAL
LESS TYPICAL
SUSPENSION
OPTIONAL COSMETIC
http://www.r3vlimited.com/board/showthread.php?t=250095
http://www.r3vlimited.com/board/showthread.php?t=259589
http://www.r3vlimited.com/board/showthread.php?t=256902
- Can we sort the sections into priority order? (#1 is more urgent or common)
- Can we exclude things that are never really an issue?
- Do we reclassify repairs that are in the wrong category?
- What missing repairs does this list overlook ?
TYPICAL
- Burnt out dash bulbs replaced with working ones
- Replaced all burnt out interior lightbulbs
- New fog light bulbs (fog lights are fully functional)
- Stainless Steel brake lines
- New spark plugs
- New fuel tubing (engine bay) / New fuel hose to the fuel rail and cold start injector
- Replace oxygen sensor.
- New distributor rotor
- New distributor cap
- New spark plug wires
- New thermostat
- New valve cover gasket
- Valves adjusted (another must for M20's), New valve cover gasket. Replace rocker shaft seals.
- New oil pan
- New oil pan gasket
- New battery
- New timing belt/tensioner (a MUST for M20 engine BMW's)
- Changed engine oil (10W-30 synthetic)
- Changed rear diff fluid (75W-90) / Diff: Redline Synthetic GL-5 Gear Oil
- Changed transmission fluid (Redline MT-90 racing fluid) / Tranny: Redline MT-90 GL-4 Synthetic
- New brake pads/brake rotors (OEM replacement from Turner Motorsport)
- New driveshaft guibo (known failure point on BMW's) with OEM BMW part and new OEM BMW hardware
- New driveshaft center support bearing, OEM BMW parts/new hardware
- New tires (Falken Ziex ZE912, OEM size)
- New belts (power steering, alternator, and A/C belts)
- New spark plugs
- New intake gaskets
- Replaced all cracked fuel lines, vacuum lines, and coolant lines
- New radiator and hoses
- Coolant flush, used BMW coolant purchased from the dealer
- Fan Clutch
- Idle Control Valve
- Thermostat Housing
- Throttle Body-Bypass (??????)
LESS TYPICAL
- New brake master cylinder with new o-ring from BMW
- New taillight gaskets
- All new exhaust gaskets and new hardware, replaced with OEM BMW parts
- New head gasket and head bolts!
- UUC DSSR Selector Rod with new shifter mount bushings
- Rebuilt shifter linkage with all new bushings
- Rebuilt calipers
- The only performance modifications on the car are new BavAuto spark plug wires, and an E32 7-series brake master cylinder for a stiffer brake pedal feel.
- Cleaned/flow tested fuel injectors at Witchhunter Performance ($135 service), all injectors at best rating
- New DME main relay and fuel pump relay (old ones were corroded)
- New ABS relay
- New crank shaft seal
- New engine mounts
- Replaced cylinder head bolts with factory updated ones
- New coolant level sensor.
- Steering rack
- Replaced an ABS sensor.
- Wheel bearings
- Replaced rear transmission seal and shifter shaft seal.
- Replaced clutch.
- Replaced shift joint.
- Replaced differential half shaft seals. Redline differential oil.
- Thermostat and Aux fan temp switch replaced
- Replaced Air flow meter
- New Catalytic Converter
- New Transmission Mounts
- Remanufactured Driveshaft
- New Slave Cylinder
- New Hydraulic Slave Cylinder Line
- Resurfaced Flywheel
- New Pressure Plate bolts
- New Flywheel Bolts
- New exhaust flanges/bolts
- New shifter cup-bushing
- Clutch Master Cylinder rebuild
SUSPENSION
- New tie rod ends and boots (Lemforder)
- New control arms (Lemforder)
- Just control arm bushings?
- Front Strut Rebuild
- New Front Shocks
- New front shock/strut mounts (Sachs)
- New front spring pads
- New front/rear sway bar endlinks
- New front sway bar mount bushings
- New rear spring pads
- New rear shock tower mounts/gaskets
- New bushing set for rear trailing arms
- Rear shock mounts
OPTIONAL COSMETIC
- New front license plate delete - bumper trim piece
- New seals bottom seals for front door windows
- The exterior modfications include: body color mirrors, front license plate delete, and rear "euro" license plate filler.
- New power antenna, new antenna grommet
- Repainted all exterior trim
- Repainted wheels
- New exhaust tip, repainted muffler and exhaust manifolds (look great)
- New M-badge on steering wheel, new BMW roundel, new chrome window moulding! (that stuff that's yellow and nasty on every other '80s BMW)
- New custom floor mats
