1 - 1 of 1 Posts
Mini Cooper R50 2002-2004 Remote Central Locking Key Programming
Hi everyone,
I'm trying to reprogram an original key to the remote central locking for the above car.
I have tried the usual "easy" procedure you turn the key in ignition, remove key, and then press unlock/lock buttons in sequence, but have found this does not work.
After a bit of digging I have found that on the earlier R50s, any keys that have lost programming or have never been programmed, need to be done using OBD interface via software.
I have an OBDII USB cable which I have used in other cars to do some basic diagnostics and programming to the ECU.
I would like to try to reprogram the original key to the car myself, but I need some help.
I expect I will need the right drivers and software to communicate with the car and potentially the correct profiles and then instructions on what options to select /procedure to follow, to code the key back to the car.
After doing a bit of reading, it appears that there are a few pieces of software available, but I'm not sure which would do the job or which is easiest/best.
I have read that INPA, EDIABAS Toolset32, or NCS may do the job, but could do with a gentle nudge in the right direction, or even better, if someone has a guide on how to achieve this, that would be brilliant!
Thank you in advance.
Sam
1 - 1 of 1 Posts
