Bmw 320i e92
59 plate
54k on the clock.
Got a misfire cylinder 4, engine check light comes on cold start. Once car is running not light appears, changed the plugs around, still misfire cylinder 4. Changed coil packs around, still the same. Moved injector to different cylinder. The misfire followed. So sent injectors away to get cleaned. Injector 4 passed the test and other 3 were slightly leaking, But no error codes were found before injectors were cleaned. Started car tonight after fitting all injectors again, misfire cylinder 4!! Also getting oil pressure light coming on after doing 80+???
Took out the vanos intake and exhaust solenoid's, cleaned them too and put back in. Still same problem,
Maf sensor had been cleaned and put back in also about a year ago!
Just seem to be going round in circles here.
Was about to sell the car on just before these problems started, any information would help a lot.
Thank you in advance!
59 plate
54k on the clock.
