1 - 4 of 4 Posts
Hey guys. Bought my first Bmw back in August, car was a buy as is. Its a 2010 535 xdrive. Car right now has 82k miles. First thing that went wrong with the car was the car going into limp mode, after scanning the code said misfire in cylinder 3&5 so i changed all spark plugs and coil packa brand new. Seemed to have fixed issue. No codes and no more limp mode but i still feel hesitation and bucking/jerking under heavy acceleration, not sure if its related to what i fixed. Then i noticed oil leaking so i had the valve cover gasket changed and it was very bad, dry and cracked and brittle. Is it possible that oil dripped in spark plugs or coils and is causing this jerking and hesitation? I have had no other codes or check engine lights
it might be your exhaust and intake solenoids. Id go with that. if you do, make sure you do a fresh oil change.:thumbup:
1 - 4 of 4 Posts
