Gentlemen,
Rogue Engineering is easily one of your first options when you think of an exhaust for an E46 M3. The exhaust note is spot on, the craftsmanship is top notch, and more importantly, the price point for these bad boys is absolutely perfect, and wont break the bank whatsoever. Don't take my word for it though, listen in to a few videos:
•Weighs only 30 lbs., 26 lbs. lighter than the factory muffler! (factory is 56 lbs.)
•100% T-304 stainless steel construction and internals, 10% larger tubing than previous version! New!
•Fully mandrel bent tubing, no crimps or flattened areas
•Mil-finished pipes and muffler, mirror polished stainless steel quad 80mm Club Sport tips! New!
•Full TIG welded construction, no lock seams or pinch welds.
•Rogue Engineering logo tastefully stamped in the body of the muffler
•Flow-through design does not create muffler "hot spots" found on chambered mufflers
•Optimized tubing sizes and minimized bends maintain exhaust velocity without compromising necessary backpressure
•Deep, throaty tone, without the drone.
•Easy to install (compared to other systems in the market)
•Will not change ground clearance
•Will not void factory warranty
•Will not affect emissions
•No permanent modifications required for installation
Rogue Engineering E46 M3 El Diablo Exhaust
http://www.modbargains.com/Rogue-Engineering-E46-M3-Exhaust.htm
We currently have these in stock ready go to, but from what I've seen in the past with these exhausts, they wont last long, they're usually gone before you can get the opportunity to ask, so don't hesitate! Rogue X-Pipes, and Rasp Pipes are also available, just ask when you inquire about the El Diablo Exhaust.
Feel free to PM, email or call me at: 714.582.3330 Extension 8002 - Jurrian
Or email me at: [email protected]
Thanks for looking, and Happy Modding!
