4181 - 4200 of 4298 Posts
Driver
Honest owners usually do not take these issues lightly, but there seems to be Tesla owners that think otherwise.
At least inquisitive minds may search for clues of the failure models, maybe the robot just happened to sneeze occasionally? :D
Also, to use your logic, the E46 unibody issue is A-OK, since it is covered by recall/class action. :p
There was a time limit on any claims where they had to be filed by a certain date, sometime in 2010 if I recall correctly. If the problem occurs after that, you're SOL. Therefore, the E46 unibody issue is NOT "A-OK". It is a perfect example of why it is much better to have a problem when you first get a new car, rather than a ticking time bomb which can kick in many miles and years down the line.
Discussion Starter #4,182
So is your plan to tear down your Model 3 to check for those problems on a brand new car?
It is a "much better" problem only if owners know about it. :p
Driver
Wow, can you get any more silly? If we use your convoluted logic here, every car should be torn down when you first get it to check for problems. :rolleyes:
Discussion Starter #4,184
An inquisitive Tesla owner(Model 3 lease, no worries) at work forwarded this, asking this to be shared.
This 6-year old Model S [email protected] The affected Model S owner(paid out-of-pocket for the repair) specifically mentioned E46:
"The only analogy I can find is the BMW E46 3 Series where the subframe was pulling against the unibody and causing cracks in the body. Guess what BMW did. Ten years of goodwill repairs regardless of mileage and design changes to stop the issue. In my case, they were just planning on sending the subframe off to recycling and moving on."
https://teslamotorsclub.com/tmc/threads/frame-failure-called-normal-wear-and-tear-by-tesla-service.135408/
Discussion Starter #4,185
Honestly logic like".... it is much better to have a problem when you first get a new car, rather than a ticking time bomb which can kick in many miles and years down the line" is what inquisitive minds usually label as bull****, but Tesla cult members appear to not care, or not honest enough to keep Tesla honest, and that is unfortunate. :rolleyes:
As far as the term "tear down", for those paying attention to Munro's Model Y teardown series, simply unscrewing/removing frunk panel are steps of tear down. :p
Driver
The only bull**** around here is what you keep trying to pass off. Boring. :rolleyes:
Discussion Starter #4,187
Emotionless inquisitive minds do not take bull****, and intend not to spread bull****. :p
E.g. inquisitive minds(including those who own Tesla) looking at the Tesla owner's fiasco of cracked [email protected] or brand new acknowledge the issue, that is all.:thumbup:
I don't get this logic either. Only obvious issues surface right after purchase. Hiddens remain hidden until they cause an issue. A visible cracked frame suggests there is more under the hood.
Discussion Starter #4,189
Check out the picture on link of post#4189, Tesla basically disassembled the whole car to get to damaged part.
The owner paid $2035 to fix, which was not that bad, but do read that the owner started hearing THUNK THUNK THUNK just backing out of parking spot, just imagine what can happen if this breaks at highway speed/on track.
Model S front suspension failure at 35k mi
https://teslamotorsclub.com/tmc/threads/front-drivers-steering-knuckle-fractured-while-driving-at-55mph-video.199103/
Discussion Starter #4,191
The OP says that the car is CPO with aftermarket sensor installed by previous owner to keep air suspension low, and Tesla paid for repair as the CPO inspection did not find this sensor.
So this case is not a Tesla factory/reliability issue.
Only because a car is lowered suspension shouldn't fall apart.
Discussion Starter #4,197
The thread does not elaborate, but aftermarket suspension mod may lower further than factory spec allows.
Similarly bimmer mods can stretch stock parts beyond factory spec leading to stock part failures.
He bought it from Tesla that way. It wasn't lowered to the floor. Nothing extreme.
I see tons of suspension failure with the Model S. Something is wrong there with the build quality.
