1 - 16 of 16 Posts
Hello guys , i own a f10 3.0D , im using and usb flash to play songs , it was working fine till one day half of the songs fail to load , if i used the : play next button the songs play but the name wont be shown. Also some of them are shown in the small screen under the speedometer if i scroll with the button on the steering wheel .
on the main monitor i see only half of the songs , other part says : LOADING , and i cant select them directly . any ideas?
USB stick degraded. You may want to replace the usb stick or reformat then load the music in again.
Premium Member
2018 540i MSport
Did the same songs play previously in the car? Can't be a DRM issue? I moved some songs from my computer to a USB previously, realized I had to remove the permission block by converting using Audials app.
Discussion Starter · #5 ·
all the songs play if i just keep pushing "next" button , but if i scroll and want to select half of the songs are shown only with numbers and i cant select them
Did you format USB in FAT32 (using Rufus software to format). I have experienced some USB stick not working like PNY or Lexar brand then I change to Samsung usb stick it works just fine. I also combined all songs in 1 file (2hrs long) and it does read and play fine.
Hope this help.
Discussion Starter · #7 ·
i changed the usb flash , still the same thing , half of the song names are shown , the other half says loading , i can still use next button to play them but i cant scroll and select them .
Discussion Starter · #9 ·
The thing is that i have been using the same usb from the beggining and i t was working fine , btw the same usb works perfectly on other cars .
I have found the USB port in my car to be VERY finicky and I have to buy a new lightning cable every year or so to keep my phone and the car talking. I recommend that you keep switching flash drives until you find one that works (then buy some identical spares).
Premium Member
the same usb flash was working for 1 year , then suddenly stopped showing half of the songs ...
USB drives wear out or become corrupted with use over time. If you only use once a week, then there might be a problem somewhere else but if used a lot (erased and reused etc.) then it might just be age. Changing your USB drive is a cheap fix. Best to rule that out first.
Premium Member
I tried friends usb didnt work either , tried new usb still same problem
Did you use a different computer for the download at any time?
1 - 16 of 16 Posts
