1 - 5 of 5 Posts
Hi everyone and happy New Year
I am getting a fault saying muti function steering wheel signal
But for some reason not getting any fault code
All the buttons work expect my cruise control
If engine is off cruise control light on cluster stay on
But if engine is running cruise control light will not stay on
Any one have any idea
I know this could be difficult with out a code
Certifiable BMW Whackjob!
By getting a fault do you mean a check message on the cluster display?
The steering wheel buttons connect to one of the comm busses through a cable wound up in the steering column, if there are no other faults from devices on that comm bus I'd start by checking the connections and condition of that cable.
Qsilver7 has posted the bus diagrams many times to see what else it talks to. For the disassembly part I'm sure everything you need to know is in a DIY for changing the steering wheel from the comfort 4-spoke to the sport 3-spoke.
sent from the future using the bimmerfest app embedded in my neural implant
Discussion Starter #3
Hello no I do not get any cheek message on dash
Radio buttons on steering wheel work buttons light up when turn on lights
Cruise control light on cluster stay on when engine is in the on setting no engine running
Start engine and cruise control light will not stay on
I lent my scanner to a friend but unfortunately he managed to brake the cable
So I am having to use a cheap scanner until I can get a new cable for my bmw icom a2 scanner
The message I am getting is
66 Signal muti function steering wheel
Steering wheel works fine
But I have no cruise control
Discussion Starter #5
Hi no all lights on instrument cluster are good
I used a friend's scanner
Which is a creator 310
It gave me some stupid fault codes
Brake switch signal no code
98 can brake signal
1 - 5 of 5 Posts
