1 - 2 of 2 Posts
hey everyone, i have a problem with my clutch. 1987 E30 325 The pedal gets stuck half way down and i have to pull it back to the disengaged position with my foot. In first gear it just gives and hits the floor. I had to tie a wire to the pedal so i could pull it back out and get the car started. Has anyone else had this problem? If so what needs to be done. Does the bolt need to be adjusted, is the return spring just worn out? Thanks for your help.
another E30 nut
.....1985 325E...... sounds like dejavou. The master is probably leaking fluid under the car. The reason it wont come up is the lack in pressure. The master is purging the build up pressure before it can pull the pedal up ,im betting 5 bucks if you crawl under your car it will be leaking
1 - 2 of 2 Posts
