Hello folks! Well like the title states, my car went into "limp mode" today coming back from work.
Basically I was driving and I see the red battery light come on in my dashboard. I figured that was ok and an easy fixed and wouldn't worry too much about it. I've been driving the car around for the past 17k miles and hadn't changed the battery and god knows when was the last time the previous owner changed it. Little did I know.. about 3 minutes after the red battery light was to come on, alarming trouble was soon to come...
all of a sudden the ABS light , brake light, and the indicator lamp for the automatic stability control light was flashing on and off (the little triangle between the speedometer and tachometer) . At this point I was freaking out as all these lights were flashing on and off besides the battery light. seconds later, the car kicked into the "limp mode." this symbol appeared besides the gear shifting indicators (!).
After all this I pulled over and raed the manual and performed the indicated reset for the fail safe mode. the first time it worked for about 3 minutes of driving time. After that I proced to pull over again and reset. This time it cleared the (!) and was able to drive it for about 30 miles with no issues. I was able to get home with out the lights coming back on.
I'am left VERY concerned as what this could mean? I've done a bit of research on the site and will try the following things.
A. Replace the battery.
and
B. Flush out and replace the Tranny fluid + the filter.
any other suggestions guys? The only thing I've done to the car lately is change out the break pads/rotors/ and break pad sensors. Perhaps I left something plugged up wrong?
I changed out the breaks about 2 months ago.
Any help would be greatly appreciated. I'am really worried it maybe a tranny issue. That's the last thing I want to worry about right now!
Thanks again
