My tires have "feathered" outer edges. Caused by bumpy curves? How to solve?
Hello to all,
On my run flats, the edges of the front tires are starting to feather. I don't know how to explain this, but I think I know you know what I am describing. If you run your hand on the edge of the tire, the outer tread is a little bumpy. Usually the feathering results is steering wheel vibrations and noise. One solution, I suppose, is to rotate the tires every 5000 miles.
Question: Might my tires need more air? Or does air pressure have nothing to do with it?
I increased the air pressure by three pounds to test.
One dealer, not BMW, told me that this -- feathered edges on tires -- is common in Southern California, and that it is caused by simply taking a curve and the suspension not holding the tire down on bumpy curves. Thus, the feathering is caused by bad roads.
What do you guys think? In previous cars, rotated the tires to reduce the feathering. But it is expensive in this car. Is rotating tires considered part of maintenance?
M
Hello to all,
M
