1 - 4 of 4 Posts
Hello everybody :)
I post in this section because this engine is used in several BMW models.
I have a knocking noise on my 640i F06 2013 when engine is warm and at idle only in Park or Neutral. Car and shifting runs fine.
If I move to Drive or Reverse the noise goes away.
I have seen many videos on youtube and i don't found the issue in comments.
Sometimes engine replacement, torque converter, rod knock, exhaust bolt, normal..
I have already removed the belt to eliminate noise of front accessories. Noise seems coming from rear of engine or between transmission and engine.
Some links :
F30 335i klackern
I would like to know your opinions before removal of my transmission which is little pain.
Thanks for help (y)
Discussion Starter · #4 ·
Here is a video of mine :
When i pull some gas and release, we can ear the noise quicker than the speed of motor
And when I select second gear the noise goes away
1 - 4 of 4 Posts
