1 - 11 of 11 Posts
Hello everyone, I have read through every page of the owner’s manual and there is no mention of this mystery switch located in the center tray. When I switch it on, the light on the switch turns green but I don’t notice anything happening in or outside the vehicle. Does anyone know what this switch could be? If it’s an after market thing, what would someone add that would need a little switch?
Photograph Car White Product Vehicle
Discussion Starter · #3 ·
Maybe. It has a phone adaptor thing in the center arm rest, so I thought the switch might have something to do with that. Since I don't have a device that it will work with, I can't test it out.
Lost but making good time
3er + 3er + 4er = 10er, Bimmers?!
How about a photograph, so we can see the switch that's baffling you? A red arrow pointing to nothing in particular on a page from the owner's manual is a little vague.
The fact that you can't find it in the owner's manual strongly suggests "aftermarket accessory," though. In which case, a definitive answer may not be in the cards.
  • Like
Reactions: dukedkt442
Agreed, that is definitely not BMW's handiwork. That's an interesting installation site, too--someone wanted the switch to be accessible but not readily observed, and put in a fair bit of effort to make it so. Moderately stealthy.
Turn on the headlights, then check whether the switch affects the tail lights. Maybe the previous owner was a smuggler, or wheelman for a heist crew.
Ignition kill switch or similar anti-theft device?
Concealed GPS transmitter for some psychopath to track untrusted offspring/partners?
E90s have two accessory power sockets near the console: One in the armrest compartment and a semi-concealed one in the passenger footwell, under the dashboard to the left of the glovebox. Perhaps a previous had a need to control power to one or both of those, without fiddling with the plugs? (Radar detector leaps to mind again.) This theory is easy to check with a multimeter...let us know if you can't find the footwell outlet.
As F10NZ stated, you might have to open 'er up and trace circuits to get more clues.
1 - 11 of 11 Posts
