I read some information about the new N20 engine and I have a question about the metal Al used in making the crankshaft. I just wonder what Al alloy they used and are this alloy's shearing strength strong enough to stand this explosive force. How durable are they?
As may be seen as early as 2013, BMW uses a new Aluminum alloy designed to last no more than 4.5 years and/or 55,000 miles. Certain materials in the alloy have bond strength both time and vibration dependent; BMW metallurgical R&D has very reliably set above limits. Absent of all vibration, alloy bonds last 15 years. Severe vibration results in a 2 year service life, unlikely to be any F30's environment. BMW has established a 99% confidence level re: 4.5 yr/55k mi limits.
After either mark, whichever comes first, the alloy will deteriorate, leading to deformation and lubricant leakage.
Designed to leak engine lubricant to the plastic catch tray under the engine, sensors will illuminate an emergency red engine graphic and disable the engine until serviced & cleared by a BMW dealer with special F30 encrypted software.
The encryption code employs a previously unknown curve and non-linear hash code that cannot be broken by any known decryption technique. You must take it to a BMW dealer.
Rest assured that your new ride is safe during the warranty period. A chemical alloy refresh is applied if, and only if, a BMW approved extended warranty is purchased, or the unit is CPO'd. Without warranty protection, however, you are certain to encounter severe penalty.
Ummmm...very good. Slow day at the office? :rofl: :rofl:
:drive:
Lmao
The crankshaft is iron (forged). The block is aluminum.
http://bimmerboost.com/content.php?...ions-plus-history-overview-and-N52-comparison
.[/QU
Thanks anyway!
According to the link provided by 'floydarogers' below, the crankshaft is forged from C38 mod, a micro-alloyed steel rather than Al alloy. The Al alloy that you mentioned is probably used for other parts such as the 5 series engine block which was bonded with Mg alloy on the outside.
On the other hand, if BMW functional parts' design life is only 4.5yrs/55 k miles, then owners should speed up the deterioration of the parts within the warranty period!
