Hi there,
My 525i E61 left me stranded on the highway yesterday. It is only 110000 km and I own it for a few months only but it already has its fair share of issues : no airbag, thermostat changed last month, rear plate light wire broken.
Yesterday I was on the highway at about 130km/h on a steep hill and it showed me an alert : "overheating, please drive slowly". I stopped as soon as I can and I plugged my Carly OBD app : no error code, fan running (albeit slowly), cooling liquid and oil temperature @120°C. The waterpump turns at about 250RPM, and it only shows deviation speed for a second when it the target speed change. I called the assistance and now the car is at home, but I am almost clueless.
For me it should be one of these issues :
- Thermostat closed, at least partially
- Bad waterpump
- Failing fan ? I have some doubts since I was driving at high speed : could the fan be needed even when there is already a fair amount of airflow?
- Failed temperature sensor
- Clogged radiator
When I changed the thermostat I was wondering if I should change the waterpump but the part being about 400***8364; I finally kept it. Thermostat change should be problem free as I had done two 650km trips with high heat (>35°C) and traffic jam without any issue (I certainly lack a temperature jauge, but I had no alert :dunno
This morning the cooling liquid level is perfect (no drop since the thermostat change), and I tried succesfully to cycle the waterpump (with this procedure with the contact on: heater on, minimum blower speed and accelerator pedal down for ten seconds). No suspect noise (I think so, it just does some typical electric motor noise...). Water pump is known to fail on the N52, but for me it looks like it is working...
I tested the fan with ISTA and it works perfectly. It was quite loud with a lot of airflow, which was not the case when I stopped on the highway.
Concerning the sensors, the car is stopped from about half a day and without the engine on I thought that I should have all the same readings. The ambient temperature shows at 24°C (OK), almost like the coolant temperature (engine, 26°C). But the engine oil and the intake air show respectively at 31 and 34°C. The inside DME temperature is at 40°C but I think that it is OK since electronics must work while connected to ISTA.
For the clogged radiator I have no clue how to test that...
Do you guys have any ideas of additional tests, ISTA procedure or preventive maintenance I should do?
I was thinking to change the waterpump and maybe cleaning the radiator (disconnecting it and flushing it with tap water). If it is not the problem it the 400***8364; waterpump will be preventive maintenance but it won't help me much :dunno:.
Thanks a lot!
- Bad waterpump
- Clogged radiator
Thanks a lot!
