Hello everyone
Please help,
I have big problem about idle, motor is n52k, i replaced
1)valve cover gasket
2)both vanos solenoid
3) new oem maf
4)valvetronic actuator oem
5) all plugs and coil tested
When car cold rpm hold perfect, accelerate perfect only when engine warm up stuck between 500-700rpm jerking and turn off, only i got 2d06- mass air flow too low, and short trim fuel go to -30(abnormal) for both banks,
When dissconect ECTS idle normally, i checked temperature show normal range,
When dissconnect excentric shaft sensor( vanos not in function) car working lets tell normal.
Tested pins of maf sensor seems all okay, i really lost ideas what can be, unpluged both 02 sensors same thing happening
I understand problem starting when car go in Closed Loop mode. Please help
Inpa picture about freeze frame.
Please help,
3) new oem maf
