1 - 1 of 1 Posts
Instructor of the Stig™
The Turner N54 Aluminum Coolant Expansion Tank Relocation Kit
Looking to add a hotside intake to your engine bay? Or do you have plans to go big turbo? Turner Motorsport has the solution for you. Long gone are the days of trying to find a new home in your bay for the weak, plastic coolant expansion tank that BMW puts in these cars from the factory. Turner's aluminum expansion tank relocation kit gives you a clean solution to relocate your coolant expansion tank from the hot side of your engine bay to the cold side. Not only will Turner's N54 aluminum expansion tank relocation kit free up space on the hot side of your engine bay, but it will also complete the performance look you're going for - featuring a wrinkle black powder coated expansion tank, with subtle Turner branding on the fill level indicator.
The N54 Aluminum Coolant Expansion Tank Relocation Kit
Features:
Maintains stock coolant capacity and expansion volume
Designed to maintain OE coolant elevation, preventing air pockets
Baffled tank ensures that air pockets cannot be introduced during aggressive driving and provides an accurate coolant level reading
Carefully designed bleed passage prevents the introduction of air as the engine cools
TIG welded 5052 aluminum construction
All bungs are machined to fit factory hose ends, no barb fittings here!
Includes a new OE level sensor, bleeder screw, and coolant cap
Tank incorporates a power steering reservoir mount
Click HERE for the N54 Aluminum Coolant Expansion Tank Relocation Kit
1 - 1 of 1 Posts
