From what I've heard, is it true that the N62TU engine came equipped with an engine oil cooler?
Just wanted to see if anyone could confirm this.
Thank you!Yes the 4.8 motor has a oil cooler and the 4.4 doesn't.
You are correct when those engines are used in the 5-series.Yes the 4.8 motor has a oil cooler and the 4.4 doesn't.
Does the N62B48 in the 6 Series have an oil cooler?You are correct when those engines are used in the 5-series.
However, the 4.4L engine came with an oil cooler when used in the 7-series.
The alternator bracket (and nightmare profile gasket under it) cover the oil cooler pickup point in the block when the oil cooler is not used in the 5-series.
Yes, the 650Ci (2006+) does have an oil cooler.Does the N62B48 in the 6 Series have an oil cooler?
Yeah, I have never really looked at the components in the oil pickup assembly on the 4.8L. If the alternator in the same place?The oil cooler, from what I understand, was intended to reduce the likely hood of needing valve seals replaced after 100k miles. It does not, however, eliminate the need to replace the alternator bracket gasket, that still fails (as many friends with 750s can attest to).
I don't recall if they are the same part #'s but they are pretty much the exact same shape (the 545's gasket goes around where the cooler lines enter the block). Pretty much the change procedure is the same, it's a PITA, except you have to get the cooler lines out of the way.Yeah, I have never really looked at the components in the oil pickup assembly on the 4.8L. If the alternator in the same place?
Is the profile gasket exactly the same one as on the 4.4L?
It is one of the top three I hope to never have to do. There other two are the starter and oil pan gasket. They look like just plain ugly DIYs.I don't recall if they are the same part #'s but they are pretty much the exact same shape (the 545's gasket goes around where the cooler lines enter the block). Pretty much the change procedure is the same, it's a PITA, except you have to get the cooler lines out of the way.
Has anyone documented the difference in oil temperature with the cooler and without? It gets a little toasty here in Phoenix too!The 4.4 L 2004 & 2005 5 series had the oil cooler removed. It was offered on cars in very hot climates, ie, Middle East and other similar climates. The cars in the states had it blocked off by the alternator bracket. Since when is summer months in South Florida not considered hot. Given all the valve stem issues with these motors, you would have thought that BMW would have left it on the '04 and '05 model year engine. '06 they did add it back. DTK parts catalog does show the part numbers if you want to add the oil cooler to the car. pretty cost prohibitive though. Might be able to find the parts on an '06 550 from salvage place for a good price.
The highest oil temperature I have seen on my 650i was 245 degrees Fahrenheit and that occurred during a hard run in the mountain roads with the outside temperature being 100 degrees Fahrenheit on a summer day.Has anyone documented the difference in oil temperature with the cooler and without? It gets a little toasty here in Phoenix too!
I run M1 0W-40 to get a little better HTHS advantage, and use 5K drain intervals because they say every 10 degrees increase in sustained oil temperature doubles the oxidation rate of oil.
I haven't seen an N62TU with the valve stem seal issue yet, however valve cover gaskets and other gaskets still do tend to leak.The oil cooler, from what I understand, was intended to reduce the likely hood of needing valve seals replaced after 100k miles. It does not, however, eliminate the need to replace the alternator bracket gasket, that still fails (as many friends with 750s can attest to).
They are out there.... maybe not as common, but they are still starting to fail / leak / smoke like the 545i'sI haven't seen an N62TU with the valve stem seal issue yet, however valve cover gaskets and other gaskets still do tend to leak.
It's only a matter of time until those guys with the N63 engines start having issues like us N62 owners. Actually, I do remember seeing two E60 550is with blue smoke.They are out there.... maybe not as common, but they are still starting to fail / leak / smoke like the 545i's
I have thought about adding the oil cooler to my 545i while I have it apart, but at this point I am so far over budget I'm not sure I want to even bother
