1 - 4 of 4 Posts
///Member
Given the link you provided....I don't think that is a BMW OEM wheel.
///Member
As for fitment on your E92, you should ask the seller what the size of the wheels are themselves. Once you know the width you'll have a better idea of what tire's to put on. And then you will know if they will fit.
The E92 should have 245/40/18 in the front and 265/40/18
Are they staggered?
Discussion Starter · #4 · (Edited)
They are not staggered, I did post the size of tires on the rims (245/45/R18). I know many drive a square setup for winter tires (those are Dunlop wintersports), my main gripe is whether they will fit in the front since they are a bit bigger 45 vs 40 aspect ratio. I've read conflicting posts but I assume it has to do with the offset of the rim itself (this is why I wanted to see if anyone knew the style or what car these came off of). I guess it's certainly possible that they arent' OEM and he's just advertising them as so.
1 - 4 of 4 Posts
