1 - 12 of 12 Posts
My F31 330d from July 2013.
has a S609A Navigation system Professional with Europe Route 2013-1 installed and I can't install the latest maps Europe Route 2020-1 because I don't have the activation code.
I try many bad codes for the new maps, but now I can't use the old maps because it ask for an activation code to start the navigation
Tha nav has been damaged or what ? I can't use it anymore, but if I put the usb stick with the new maps, it ask to update or not. I can't update because I don't have the activation code for the new maps
The rest of functions are ok. CD/RADIO. settings, are ok...
Discussion Starter #3
I generated the FSC Codes with BMW CIC/NBT Keygen v1.91 thru
VIN F809969 and by Date: 201307192048
Can I stiill read the 00de.bin with e-sys even the Navigation isn't working?
Can anyone help me with a valid FSC, all the FSC codes I generate are not valid.
VIN: F809969
Prod. Date: 2013-07-23
Region: Europe
Map Type: Next
Maps Update to: Road Map Europa West Next 2020-1
Update: thru USB
Super Moderator
VIN: F809969
Region: Europe
Map Type: Next
Update: thru USB
DE is for next.
DF is for route.
That is why it is invalid.
Discussion Starter #5
Sorry, but I don't get it. How did you get on route, where did you get the DF?
I was quid sure i had Next, but now I'm in doubt.
Super Moderator
Next is for NBT systems.
Route is for EntryNav systems.
There is no free generator for route systems.
You need correct map version for hardware and matching FSC code.
Discussion Starter #7
the evaluation of the BMW VIN decoder says that a S609A Navigation system Professional is installed.
Thats why I downloaded the "BMW Road Map Europe WEST NEXT 2020-1"
I dont have EntryNav so I dont need route. I apologize but what do I misunderstand?
Discussion Starter #8
Now I get it, I wrote. I think that was a typo.
I think it's Europe Next 2013-1 installed, but I can't reproduce it because I can't get into the Nav menu anymore.
What can I do?
Premium Member
F809969 has NBT Head unit and requires NEXT Map. You need to load Europe NEXT 2020-1 and use correct FSC Code for it.
Discussion Starter #10 (Edited)
OK, good to know, that I am not totaly wrong.
BMW Road Map Europe WEST NEXT 2020-1 thats what I have on a USB stick.
I put it in center console. NBT founds update and asks for a FSC. But all FSC that I generating are wrong.
Even the old maps wont work, because it asks also for a valid FSC.
Thats how I try to generate the code.
Today I will get a ENET cable, and I hope so that I can read with E-Sys the FSC code.
I am a afraid that i am delete the valid FSC thru the wrong FSC
Then I will try to generate the FSC by File instead of by Date
Is it still posible to read the fsc with E-Sys?
Premium Member
...Today I will get a ENET cable, and I hope so that I can read with E-Sys the FSC code.
By date does not work, and never has. You need DE file from HU.
Discussion Starter #12
I am so happy, despite the wrong FSC codes and the deactivation of the navi. Was it possible to read the de.fsc code with E.Sys. afterwards, it also works with the FSC code for Next 2020-1.
My new winter project will be coding the f31
Thanks to all who helped
1 - 12 of 12 Posts
