1 - 9 of 9 Posts
I'd like to replace unit in pic with a MK IV unit from eBay. Is it a direct plug and play, does it require coding and if so how is that accomplished? Thanks
It is plug n play. It does not need coding, but you may need to update the SW to the last v31/v32 release. If you have a widescreen display, you may lose use of the INFO and SELECT buttons, though this can be re coded.
Discussion Starter #9
Purchased a MKIV nav unit and installed it today, and the screen, radio, speakers, seem to work.
1 - 9 of 9 Posts
