1 - 20 of 59 Posts
· Registered
I have a retrofitted nbt evo in a 14 f30 . Recently the navigation stopped working . It has been stuck on the grey loading screen . I tried to reload current map and an update . I kept receiving the message "data on usb unusable . please insert new usb. " I used multiple different usb sticks and made sure they were formatted to fat32. All the certs are accepted . Everything else works . Carplay, bluetooth, sdars, and even accessing songs stored on hard drive . I was told its possibly a failed hdd. Just looking for some direction on diagnosing this problem. i would think that if hdd is bad other features would have failed . I'm trying to avoid removing it and sending it out . Any and all help is appreciated .
Thank you .
· Premium Member
Delete current Map Data with Tool32, then try installing new Map.
· Premium Member
Try this:
a) Launch C:\EDIABAS\Bin\TOOL32.EXE (Run as Administrator and make Sure Windows Firewall is disabled)
b) Hit F3
c) Load C:\EDIABAS\Ecu\NBTEVO.PRG
d) In the "Select Job: F01" window, select "steuern_routine"
e) Press on "argument wizard" and from top drown down box select "SAFEMODE_HDD", and then from right side drop down "safemode aus"
f) Hit F5
g) "Results" window should show "JOB_STATUS = OKAY"
h) In the "Select Job: F01" window, select "steuergeraete_reset"
i) Hit F5. "Results" window should show "JOB_STATUS = OKAY" and NBT2 Head Unit should Reboot
Then make normal map update using EVO map on USB Drive and EVO Map FSC Code in "FSC" Folder.
  • Like
Reactions: dayvg
· Premium Member
"SAFEMODE_HDD" argument is for "steuern_routine" not "steuergeraete_reset".
· Registered
Discussion Starter · #12 ·
Font Rectangle Pattern Technology Design
followed all steps from beginning again. Ended with this result on tool32. Still at starting navigation screen and not recognizing update. I reformatted usb to fat32 again and reloaded map update with same result.
Font Parallel Pattern Rectangle Document
These are the files I have on the root drive of usb.
· Premium Member
Do exactly this:
1) "steuern_routine" with "SAFEMODE_HDD" & "safemode aus" argument
2) "steuergeraete_reset"
3) "steuern_routine" with argument NAVI_MAP;STR;0x01
4) "steuergeraete_reset"
Then try Map Update.
USB looks correct as far as map, but there is no "FSC" folder with FSC Code.
· Registered
Discussion Starter · #14 ·
Font Technology Screenshot Paper Publication
followed directions precisely. This was the only step that came back with an error. I added fsc folder with fsc codes inside to usb. It still does not recognize update just continued starting navigation system message
· Premium Member
Ok, not sure what issue is then. I think until existing map is deleted, it's not going to take new map.
· Registered
Discussion Starter · #16 ·
So if I understand that error message correctly. Something is preventing tool32 from deleting old map data. Is there a test I could run in tool 32 to see what ecu error is ?
Again thank you for all your time and effort trying to help me resolve this
· Premium Member
Nothing I know of. Maybe HDD is just jacked up...
· Registered
So are you saying from the information you’ve read in the post that you believe it’s possible the hdd is bad ?
It’s almost certainly the HDD
1 - 20 of 59 Posts
