With EVO Head Unit, Its more than just VO Coding with modified FA. PM Sent.
Emin değil. FA Option 813A NATIONAL VERSİYON FRANSA'nıza mı eklediniz?
PM gönderildi.
VO Kodlama Bölgesi ve Dil Değişikliğinden sonra CAFD'yi Enjekte etmenize gerek yoktur.
[/ALINTI YAPMAK]
PM gönderildi.
[/ALINTI YAPMAK]
Thank you very much for your answer and help.
I forgot to say, i am adapting my car from japan to france
Hello Shawnsheridan,
I have completed all the installations (e-sys) and I changed the salapa options from VO for region and lalanguage (japanese to germany), I write to VCM, I coded HU_NBT , car is accepted, everything is normal but to activate the navigation " 00A0 is for Navigation System Professional ECE/US " i think i need to do this , but I still have "00A1" how can i change this? where can I find it "fsc cert, sig cert..." can you please help me? Thank you from now.
I finally got mine converted needed to purchase a program that I assume flashed the NBT2 to an Australian/New Zealand version.
As stated above when I converted my unit. Its not just a few esys codes to change you need to have the unit flashed with new firmware. I ended up paying $100USD for the software to do this, that included a software key was was linked to my vin.
Getting the radio to NZ specs and language etc is just a few esys codes. Just not navigation.
Do you remember where you got the software and keys from?
Hello, I'm in a similar boat
I have Japan Evo Maps
I want to change it to Europe with Apple Carplay.
I’ve read others have used feature installer to region unlock and load fsc but it’s not worked for them.
Some are saying to VO code.
Can anyone point me to the right direction?
Thanks in advance!
PM sent.
I am in the same boat. Need to change from Japan to Southern Africa. Any help will be appreciated,
Same boat on a 2014 F15 EVO IP4, need to change from North America to South America, already got the Map files and FSC Code
