Many thanks, sought I needed to code.Then use them. Nothing more to do.
it is coding + patch.Hi, can someone help me with region change from USA to ECE on NBT evo navigation?
I have e-sys and I am familiar with it, just need the steps which should be done.
The vehicle is a F36 4 series.
Thanks in advance.
esys alone cant help with convert maps, if want assist remote pm meHi, can someone help me with region change from USA to ECE on NBT evo navigation?
Thanks in advance.
Hello! I need same problem (change region from Japan to Europe). Can you PM me how to fix it?Then use them. Nothing more to do.
Need edit FA to europe, and after the best patch Japan to europe. Pm text me if need assistHello! I need same problem (change region from Japan to Europe). Can you PM me how to fix it?
Send me vin numberHello! I need same problem (change region from Japan to Europe). Can you PM me how to fix it?
0P56018Send me vin number
For some reason I can't write PM to you. Can you do it to me?Need edit FA to europe, and after the best patch Japan to europe. Pm text me if need assist
Yes, I have it. And E-SYS alsoYou have enet cable?
ThanksYou also need map loaded in usb 64gb or bigger. Im sending my whatsapp in pm
interestingMgu change Korean to EU
