NCD / CAFD Tool V0.2.5 Alpha
Update: 4/13/2014 V0.2.5 Alpha
This is a direct drop-in replacement. If you have customized settings, just replace the executable to keep your settings intact. Settings are kept in NcdCafdTool.exe.Config file.
What-If FA-CAFD
This feature uses ncd file or CAFD file for input. If you use *.ncd, the tool will use the version of CAFD used to generate your ncd file, meaning the CAFD associated with your current I-Step. Opening CAFD allows you to use any version.
FAFP will be retrieved from CAFD and any main series not used by CAFD will be excluded. Selected Build Level will control available options.
You can quickly find an option by selecting an item, then typing it in, e.g. 6WA, 6NS...etc.
Results are determined by a particular CAFD and not every option will have an effect on the selected CAFD. Don't select any options that obviously don't have any code associated to it, e.g. 130, 23B
Results are meant to be use as a guide only. They are by no means authoritative or definitive. Verify and use at your own risks.
Lastly, this tool is free. Never pay anything for this tool.
Rename to .zip View attachment NcdCafdTool_V0.2.5.pdf
Alternate Download: Google Drive
- Added "What-If FA-CAFD" feature
- NCD/CFAD Comparison tool now excludes "Comments"
- Minor bug fixes
What-If FA-CAFD
