1 - 5 of 5 Posts
2003 540i m-sport
Does any one have any recommendations for replacement motor, my timing chain blew and of course have bent valves vanos is questionable ect is it better to just replace the engine or repair? if so who is a reputable seller of these engines. any help would be greatly appreciated:dunno:
How many miles did you have on the car?
It would be cheaper and quicker to drop another motor in.
Seek to understand,^Value
These were written for this question:
- Summary advice to provide users who suspect a major engine repair due to overheating (1) (2) (3) (4) & how to test an engine for a blown head gasket, cracked heads, a warped block, stripped head bolt threads, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & what are the major factors in deciding whether to rebuild the engine, replace the engine, or sell the car (1) & a DIY for replacing the I6 M54 head gasket (1) (2) & replacing the V8 M62TU head gasket (1) & why these engines are so prone to heat-related damage in the first place (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what engine swaps are most recommended (1) (2) (3) & where to obtain a new or rebuilt head (1) replacement short block or long block (1) (2) & how to lift & remove the engine (1) & the most recent real-world results from the last 50 people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39) (40) (41) (42) (43) (44) (45) (46) (47) (48) (49) (50)
Did someone tell you that the valves were bent? How did they determine that?
Timing chains don't "blow." Get a second opinion.
JohnathanDM
i would get a second opinion the issue engines for any e39 ruffler cost as much as the car is worth.... worse case Scenario make it a weekend project car and put it back one piece at a time I do wish the best of luck tho!
1 - 5 of 5 Posts
