*Solved*
Having some serious issues with car in limp mode? after my coolant tube repair. Had a transmission fault and car will drive OK just doesn't have more than 2nd gear. So, I buy one of those k-line adapter cables from BCABLES and a Carly bluetooth adapter from Amazon.
Ok, so here is a little background before my woes:
Purchased the car from a friend a few months back knowing the transmission was out. My friend had the trans oil service done and the lines replaced, and a couple days it just quit on him. Actually what had happened I found out when getting it home was the trans oil line had partially come off the oil cooler, so I snap the line back on and fill the trans with fluid. Voila!
Ok, well the transmission never shifted perfectly but what the heck, it was fun to drive and I drive it a couple months, have an occasional Transmission malfunction error that goes away after restart.
Then the dreaded coolant pipe incident! So I stop the car after overheating and see That leak we all dread and tow her home. (I had already read up on this and had planned a future attack on the issue.) I figured while I'm in the engine, go ahead and replace the timing over gaskets, valve cover gaskets, spark plug tubes and a new water pump. My friend said the alternator was new so I left it alone. I had already installed new spark plugs a month prior as well and had just performed my first engine oil change. I also charged the new battery (NAPA Legend 75) at the battery terminals while the cables were off just as a precaution before firing it back up after the repairs.
So, after assembling the engine I flip the ignition switch to initialize the servos for the vct and whatever else needed to reset, actually I did this a couple of times and waited a minute between each (very cautious). The I fired her up. To my amazement, it actually started and ran OK, not perfect but OK. So I hook up the obd reader I had, grabbed a few cyl misfire errors and went back under the hood to replug all my sensors and coil packs. Smooth as butter idle! SO after warming it up, I decide to go for an easy spin around the block but the transmission malfunction came up when putting it in drive. oh no! I went ahead and drove it a very short distance thinking it would magically clear up. Seemed like it only had 2nd gear and would not accelerate much at all! Also tried manually shifting to no avail. So since I had already some transmission errors previously and the rough shifting, I decide to order some new solenoids, a Sonnax zip kit, four hose looking seals and transmission adapter seal that is recommended, and valve body separator plate.. Everything went smooth for that install, even the mechatronic sleeve wasn't too bad to remove or reinstall (didn't change it since it didn't leak). So after a fresh fluid refill, running it through the gears to ensure air bleed and warming the trans to spec per fluid level instructions, I try again. Still have the transmission error. So I try a drive again. Goes into gear a little hard in reverse but nice and firm engagements now. Still having the active steering and trans faults so I decide to buy the cable and Carly to reset everything. ughh No dice. The cable refuses to communicate with the car with INPA and the Carly does OK, I actually did some coding, battery registration on new battery I bought after purchasing car, and did a full diagnostic (after prior clearing the previous codes with my obd scan tool).I reset the faults and performed a second diagnostic to be sure. Below is my report, minus the German and insignificant stuff. Crazy stuff! No way can I have this many errors, didn't before the overheating issue with the odb scan tool. I suspected the battery (charged it some more after registration) and the alternator but battery seems to check OK with my multimeter. I did get a "Check battery cables" error after doing my diagnostic and driving the car to the end of the driveway as well (hence why I suspected the battery) but everything checks out OK?! Intelligent battery sensor? Cable left unplugged/not seated fully in ECU? Crankshaft sensor? Is there any advice someone can give? Where should I check? I'm at my wits end over this, and quite clueless even after scouring the internet an the forums for a hint/solution. Please Help!
Carly Diagnostics
Engine:
CAN timeout EGS Code: 002DCA
Air mass meter Code: 002D0F
Thermo-oil sensor Code: 005D60
Temp sensor coolant temperature Code: 002EEA
Camshaft control outlet Code: 002A88
VANOS camshaft control outlet Bank2 Code: 002A89
Camshaft control input Code: 002A83
Intake-VANOS 2 Code: 002A84
Ignition coil cyl. 6 Code: 002E29
Ignition coil cyl. 3 Code: 002E26
Ignition cylinder 7 Code: 002E2A
Ignition coil cyl. 2 Code: 002E25
Misfire detection error summation Code: 0029CC
Misfire detection cylinder 1 in 1 Firing order Code: 0029CD
Misfire detection cylinder 4 in third Firing order Code: 0029D0
Misfire cyl. 5 Code: 0029D1
Misfire cyl. 6 Code: 0029D2
Misfire cyl. 7 Code: 0029D3
Misfire Cyl. 8 Code: 0029D4
Misfire detection cylinder 3 in 2 Firing order Code: 0029CF
Misfire detection cylinder 2 in 4 Firing order Code: 0029CE
Power-management:
power failure Code: 002DEB
CAN message time-out monitoring ETC Code: OBD03 P320D
B Camshaft Position Timing Over-Retarded (Bank 1) Code: OBD03 P0015
B Camshaft Position Timing Over-Retarded (Bank 2) Code: OBD03 P0025
CAN message time-out monitoring ETC Code: OBD07 P320D
DV-abortion adjustment, because the environment Code: 002D03
DSC AFS exchange DSC signal invalid Code: 005F62
CAN error message Code: 00D358
Steering angle sensor Code: 005F0E
Right rear wheel speed sensor Code: 005E4B
Rear left wheel speed sensor Code: 005E3D
DME error: invalid values Code: 005F76
Airbag B-pillar left ECU OK, no Fault Code
Airbag B-pillar right sorry, unknown fault Code: 00991D
DSC / Brake:
Active Roll Stabilization DSC CAN error message Code: 00D358
Satellite front left door ECU OK, no Fault Code
Satellite front right door ECU OK, no Fault Code
Satellite B-pillar left ECU not present/no response from ECU
Satellite B-pillar right ECU not present/no response from ECU
Satellite center ECU OK, no Fault Code
Transmission Control:
Transmission / Getriebe GS 19 no response from ECU
Transmission no response from ECU
Gear switch / Gangschalter no response from ECU
Instrument cluster:
CAN signal fault transmission Code: 00A3AA
ID failure Code: 00A54E
ID failure Code: 00A54F
CAN signal fault indicator Code: 00A3B1
CAN signal fault DSC Code: 00A3B9
CAN signal fault immobilizer Code: 00A3AC
CAN signal fault missing Code: 00A3A9
CAN signal fault engine idle Code: 00A3AE
Central info display SV-block checksum incorrect Code: 00A46B
Brake light switch faulty Code: 00A58D
Light Stepper motor box fault Code: 009CBD
Immobilizer System:
CAS Supply Error Code: 00A0B2
Input P N signal fault from EGS Code: 00A0B1
Signal detection error rate Code: 00A0B5
Park Distance Control Inverter VL Code: 009E37
Inverter VML Code: 009E39
Inverter VMR Code: 009E3A
Inverter Board Code: 009E38
Active cruise control ECU not present/no response from ECU
Engine cowl Code: 00A69A
Hall sensors supply connector A Code: 00A692
Hall sensors supply connector C Code: 00A693
Temperature sensor of the pressure pump Code: 00A698
Exceeding the speed Code: 00A6A4
Communication with the airbag SG disturbed Code: 00A375
Leakage failure Code: 00A530
Systems: Gateway:
PT-CAN WAKE-info difference Code: 00932F
Steering column switch ECU OK, no Fault Code
Fuel pump sorry, unknown fault Code: 00612C
sorry, unknown fault Code: 006139
sorry, unknown fault Code: 006140
sorry, unknown fault Code: 006145
sorry, unknown fault Code: 00CE93
sorry, unknown fault Code: 00CE9A
Car Communication:
Computer CCC Ring break diagnosis error Code: 00E190
MASK ECU OK, no Fault Code
Steering column module: initialized position data Code: 009FED
Car Communication ECU OK, no Fault Code
Anti-theft alarm system: unknown failure Code: 009D00
Errors in the internal battery Code: 009D12
CAN fault Code: 00D947
Car Body Module TR failure Code: 00A43D
KBM under voltage Code: 00A409
Carly Diagnostics
Engine:
Power-management:
DSC / Brake:
Instrument cluster:
Immobilizer System:
Systems: Gateway:
Car Communication:
