1 - 18 of 18 Posts
Alright this my problem. I just bought a 1992 BMW 325is with a few mechanical issues, and happen to be able to get my hands on a 1995 BMW 325i motor off a friend and so I began to swap.. I have everything in already just not put back all the way together, well I was wondering if I can still run same harness and ECU of the car on a 95 engine block? Or do I have to swap harness and ECU too?
D'oh, You Kids!
1984 633CSi, 1985 635CSi, 1985 325e, 1987 325is, 1993 325is, 1995 318is, 1995 M3, 2003 F150
If the 92 had a non-vanos M50 (I believe all the 92s did) no, you'll have to swap harnesses and ECUs too.
D'oh, You Kids!
The '95 325 should have the sensors and the harness will have the needed connections. The ECU will have provision to utilize those sensors. That's why you need the ECU and harness to match the engine.
Officially broke
Plug everything in and if you have more then just the vanos connector left it probably won't work. M50tu is the "technical upgrade" to the m50 I don't know if they added or changed anything other than the vanos.
If it was just the vanos added I don't see why running the ecu you have would be a problem.
Discussion Starter · #8 ·
There is one other plug that is near the valve cover that's supposed to be a male plug but is female and I was wondering if i can swap the plugs from my 92 block but then there's no vanos will that mess with my cam timing?
Officially broke
No the vanos only engages at high rpm and is for performance so you will just loose a little power in high rpms
Discussion Starter · #14 ·
Need help non vanos to vanos swap
I swapped a 1995 BMW 325i obd1 vanos into a 1992 BMW 325is obd1 non vanos shell not realizing the difference I bought a 1994 325 harness the engine to harness wires are connected but theres a small CPU harness plug and a pin plug that can't plug into anything? Is there any way I can run the engine mechanically as in take off wires and ect.. Or what can i do to start and drive? Need help asap
D'oh, You Kids!
The "circle round plug" I believe is the diagnostic port. It doesn't connect to anything. It's held in a ring bracket on the side of the engine. The smaller rectangular multi-pin connector is (I think) the anti lock brake harness, and plugs into the anti lock brake computer just like the larger one connects to the ECU.
Discussion Starter · #18 ·
How can I run it without the transmission control module? My 92 harness only had one of each how can I get remove the wires I don't need or how can I start them without the TCM plug (small ecu plug)
1 - 18 of 18 Posts
