1 - 4 of 4 Posts
Just got a 99 bmw 323i. I***8217;ve got multiple cylinder misfires on 1,2 and 3. Didn***8217;t mess around with changing coils around to see if the issue is coil related because I don***8217;t believe that is the issue. There is also a popping noise coming from the intake which i can only assume are small backfires. It only really does it at start up.
Anyways, while the car is running, if I unplug the MAF the cars idle will straighten out. No popping. No choppy idle. I got to looking and the intake boot is torn in 2 spots. Big tears too. I just ordered a new intake boot for the thing and those will be in shortly.
I guess my question is, could the major vacuum leak cause the computer to trick the engine into running fat/lean and create backfires? Is unplugging the MAF and seeing an improvement a sign of a vacuum leak? Also, would a major vacuum leak cause a multiple cylinder misfire? Just to add a little bit of info. When the MAF is plugged in and I take the oil filler cap off it will bog down bad and stall. If I do the same with the MAF unplugged it will act as it should and change the idle slightly.
I***8217;m new with bmw***8217;s so any help would be appreciated.
Keeping it surreal
First step in any diagnosis is to get the codes read, then post those results here. Codes are expressed as "P0123", etc.
Discussion Starter #3
I***8217;ll have to go recheck but I***8217;m certain it was p0300 p0301 p0302 and I***8217;m pretty sure a bmw specific code. I***8217;ll echeck and get back
All were misfire related
Discussion Starter #4
Ok. I***8217;ve diagnosed it. Here are he codes I got
P1250 - No DTC definition found
P0300 - random multiple miss
P0130 - oxygen sensor circuit bank 1
P0302 - cylinder 2 miss
P0303 - cylinder 3 miss
P0301 - cylinder 1 miss
P0170 - fuel trim
P1188 - no DTC definition found
P1182 - no DTC definition found
P0142 - oxygen sensor heater circuit bank 1 sensor 2
1 - 4 of 4 Posts
