Need help in coding FEM after replacement
1 reading
59K views 60 replies 15 participants last post by  Brizoo
#1 ·
Hi.
I need to replace FEM module in my car becasue I have problem with unlocking car. Probably some relay failure because wiring and fuses are ok.
So I bought used FEM and installed in my car.
In E-sys is different VIN, different FA (VO), everything is from donor car.
How to program FEM with my VIN number, and how to import proper FA (VO) to FEM ?
#2 ·
You will need to flash FEM to write car VIN to it, and then I believe there is an alignment procedure in ISTA to align FEM to car DME.
#4 · (Edited)
See here regarding Flashing FEM:
http://www.bimmerfest.com/forums/showthread.php?p=8737326#post8737326
The alignment procedure is in ISTA/P, "EWS/DDE calibration" tab, and it synchronizes EWS and DME control modules. So, maybe it is needed only if DME is replaced, and not if FEM (CAS) is replaced.
Configuration is not stored in DME. It is in ZGW and FEM (CAS).
#5 · (Edited)
Shawn thanks for the info.
So I need to flash FEM by this guide from link You provided.
I have few more questions.
1. if FEM is dependand from other module do I need to flash all of dependand modules ?
2. in step 3 "Connection via Gateway URL". This is important ? My new FEM has different VIN from my car so if during flashing procedure VIN in FEM changes this may interrupt rest of process.
3. in step 5 "Read and save FA". When I read FA I get only 12 modules (probably from car donor of the FEM module). My original FEM after read FA shows 21 modules. Is it important, or this correct number of modules will appear after flashing procedure ?
4. in step 8 "Create an SVT Target:". How to choose I-step target ? Is it possible to flash with I-step target with the same value like I-step shipment ? Or is this depends from pszdata version ?
5. in step 13 I read VIN from FA or insert VIN by myself ?
One general question.
Where is stored information about car keys ?
When I installed used FEM in the car my key won't work. The car shows that key is not in the car. So the car won't start.
#6 ·
1. I would flash all other ECU's with Dependency as well.
2. I would flash with Connection via VIN.
3. Try Read ECU instead of Read SVT. It is important they all show else you may not be able to flash ones with dependency.
4. I-Step target is not selectable, as it is fixed based on yoru current PSdZData version.
5. Read VIN from FA.
Key information is stored in FEM (CAS).
#7 · (Edited)
OK.
Is it correct, even when during flashing FEM the VIN will change ?
Ok, so unless all modules shows up I don't go further with flashing ?
For flashing should I use latest available version of PSdZData ?
What if this will give me VIN from car donor of FEM module ?
After FEM replacement do I need to add my key to new FEM?
How to do it ?
#13 ·
I have read both, that Immobilizer (EWS4) is an issue for FEM, and that it is not. For sure it is an issue for DME replacement. I don't think attempting to flash FEM would do anything to DME. Worst case is FEM takes VIN, and still won't sync / decrypt key with DME.
#14 ·
I still have the actual FEM from my car.
Is after flashing the "used FEM" I will be still able to use the original FEM from my car ?
With FEM from my car is something wrong, I can't open the car with key fob, dash button and CA. Thats why I need new FEM. I already checked all fuses and wiring. So the failure of FEM modul is only explanation.
Is this procedure with replacement FEM will be easier with new empty FEM ?
#17 ·
If the method with flashing used FEM will not work, it will be possible to get back to original FEM from my car ?
I still have this original FEM.
Flashing used FEM will have no affect on your original one.
#21 ·
This two options in E-sys should be enabled only when I want to write VIN to module ?
What charger is good for flashing to avoid interruption during process ?
No, these have nothing to do with writing VIN to module. VIN is written to module during flash, either taken from FA or manually specified on the TAL screen.
Use any charger good for 50 amp minimum.
#29 ·
It depends on the module. I have no idea on FEM. My guess will be around 20 - 30 minutes.
#31 ·
Iv'e seen CIC take 45 minutes, which is why I guessed 30 minutes for FEM given its size. Time depends too on how old the current firmware is relative to the new firmware, and how many firmware files actually need updating.
#36 · (Edited)
I was trying update FEM, but ended with this error:
TAL execution started.
VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197]
[Exception - UNKNOWN] FA must not be null when trying to execute a TAL containing coding transactions
Fatal error while executing tal!
Asynchrone programming failed! [C049]
FA must not be null when trying to execute a TAL containing coding transactions [1358]
In E-sys settings I have unchecked this "Update VCM after TAL execution".
#39 ·
That is normal. FEM_GW is the part that is Central Gateway module, and FEM_BODY is the rest of FEM (FRM, CAS and JBE).
#44 · (Edited)
need more help.
after installation of new fem in car I cant flash it.
errors in E-sys:
I need assistance by teamviewer.
i tryed to code FEM_BODY but it resulted with error:
Caf's suchen
Tal wird generiert
Abarbeitung wird gestartet
ExecutionID=2015/02/14-16:34:49.824
[] prepareTALExecution started
MCDDiagService<id=410649, job=com.bmw.psdz.jobs.common.MCD3_PrepareTALExecution, service=RC_STEUERN_RESET_ACT_LINE - RoutineControl SteuernResetActivationline, description=error: negative response : requestOutOfRange, link=FEM_GW_10_ETHERNET>
MCDDiagService<id=410600, job=com.bmw.psdz.jobs.common.MCD3_PrepareTALExecution, service=RC_STEUERN_RESET_ACT_LINE, description=error: negative response, link=#RtGen_MultipleEcuJob_LogicalLink>
MCDDiagService<id=36900, job=com.bmw.psdz.jobs.common.MCD3_PrepareTALExecution, service=RDBI_ADS - ReadDataByIdentifier ActiveDiagnosticSession, description=error: timeout, link=Physical request to ECU with address 0x78>
[] prepareTALExecution finished
[] prepareVehicleForCoding started
[] prepareVehicleForCoding finished
[FEM_BODY - 40] prepareECUforCoding started
[FEM_BODY - 40] prepareECUforCoding error
[FEM_BODY - 40] There was an error during TAL execution, please check the log files.
[FEM_BODY - 40] finalizeECUCoding started
[Exception - FEM_BODY - 40] SVK-Ist does not match expected SGBMIDs for ecu ECUId:FEM_BODY_0x40. Excpected: [hwel_00000792-000_004_008, hwap_00000f26-255_255_255, hwap_00000f29-255_255_255, hwap_00000f2b-255_255_255, hwap_00000f2c-255_255_255, hwap_00000f2d-255_255_255, hwap_00000f2e-255_255_255, hwap_00000f30-255_255_255, hwap_00000f32-255_255_255, hwap_00001263-255_255_255, btld_00001556-003_101_010, swfl_0000155e-004_102_040, swfl_0000155f-000_003_029], Actual: [hwel_00000792-000_004_010, hwap_00000f26-255_255_255, hwap_00000f28-255_255_255, hwap_00000f29-255_255_255, hwap_00000f2b-255_255_255, hwap_00000f2c-255_255_255, hwap_00000f2d-255_255_255, hwap_00000f2e-255_255_255, hwap_00000f30-255_255_255, hwap_00000f32-255_255_255, hwap_00001263-255_255_255, btld_00001556-003_101_010, swfl_0000155e-004_104_040, swfl_0000155f-000_003_029, cafd_00000794-004_228_010]
[FEM_BODY - 40] finalizeECUCoding finished
[] finalizeVehicleCoding started
[] finalizeVehicleCoding finished
[] finalizeTALExecution started
[] finalizeTALExecution finished
TAL execution finished
TAL-Execution finished with status: "FinishedWithErrorInTransaction". [C207]
TAL execution finished. Duration: "18s". [C206]
Abarbeitung beendet
#45 ·
need more help.
errors in E-sys:
[Exception - FEM_BODY - 40] SVK-Ist does not match expected SGBMIDs for ecu...
This "SVK-Ist does not match expected SGBMIDs for ecu..." means you have chosen an improper I-Step Shipment when you made your SVT Target (SVT_soll). The problem is that this ECU is not original. So it came with a different I-Step Shipment then your car's actual I-Step Shipment, and you have no way of knowing what the right I-Step Shipment is for this ECU.
So, redo flash, but this time after you calculate SVT Target (SVT_soll), check the box that says "HW-IDs from SVTactual" and then Save it.
If it still does not work, the only thing you can do is try different I-Step Shipment dates until hopefully one works. This is simply Trial and Error.
