1 - 2 of 2 Posts
· Registered
R5/FCX(II) Scan/Reset Tool
I just bought a Peake R5/FCX(II) Scan/Reset Tool and tried for the first time in my 1998 E39-528i (build 11/97).
Well after turning the ignition key on and inserting the scan tool into the 20 pin connector, nothing happens, not even a light on the scanner's display.
Tried different scenarios, turning ignition key on/off/on again, removing/reinserting the tool with no luck.
I made sure the tool was inserted properly with the faint line on the side of the tool been just even with the top of diagnostic connector.
Any one has any suggestions/clues on what to check or do next?
Thanks you
1 - 2 of 2 Posts
