For the past two summers whenever I drive my 6er at night the freaking passenger side low beam flickers once every 2-3 minutes.. For the past 2 months though the light will flicker every 2-3 minutes but will then eventually stay off completely and give me an error in iDrive stating that I have a passenger low beam malfunction.. This passenger side assembly also has an adaptive headlamp error that has always popped up.
Now, I have replaced the red ignitor, the Ballast on the bottom of the headlight assembly, and the actual D2S bulb (twice). The bulbs are the 8000k eBay bulbs, I think they are called Super Vision or something.. I have been thinking that the bulbs may be the problem, but then if the bulbs were the problem wouldn't the driver side bulb also be doing the same thing?? There was condensation inside of the headlight a while back when I went to one of those conveyor belt car washes but no since then because I only hand wash the car now.
I am about to blow this car up or get rid of it because this is frustrating me so much.. Im thinking of taking the car to the dealer for a diagnosis of the problem, but they are pretty much guaranteed to screw me on the diagnostic charge.
Does anyone have any suggestions or have you had any problems similar to this?? Should I replace the headlight bulbs with some Phillips brand headlight bulbs? Is it possible for the little Stepper Motor Controller (SMC) on the side of the headlight could be causing this problem?
Looks like the cheapest Brand New headlamp is around $1200 shipped, and the cheapest used (Insurance Quality) Headlamp assembly is $800 shipped... Thinking of pulling the trigger on the used one...
