Ok guys so I've been working on the turbo replacement and finally am coming to a close... And I've got a couple issues that have me baffled and I need some wisdom!!!
First, the water pump is running continuously and will not cut off until I disconnect the battery.
I also cannot get an oil level reading... Screen shot to follow
Car runs perfectly at this point though....so there's that...
I had to remove the water pump during the turbo install, it is less than 20k old and is an all metal Piersburg from FCP... Which coincidentally worked perfectly before performing this work, as did the oil Level sensor. There has to be a common fault here... I just don't know where to start...
I had read that if the coolant temp sensor (Front of motor fails, the fan kicks on in high) And can confirm that when unplugging this sensor the fan kicks on... Is there a similar sensor that would cause the water pump to fully engage and not stop?
Any help would be greatly appreciated, I was looking forward to wrapping this job up today...
Did you come across two connectors that could be interchanged? Did a wiring harness get crushed or pulled hard when lifting the engine for clearance? Any connectors that felt funny trying to reconnect?
It might help to connect with ISTA and see what's unhappy.
Ok so a little more research has gotten me to this conclusion... Anyone concur or have anything to add?
The BSD communication line consists of the IBS sensor, oil level sensor, alternator and the WATER PUMP and it's been documented that when the water pump acts up it messes with communication of all the above... And I have an IBS communication error, as well as an oil level sensor error...
11 51 000 Removing and installing/renewing coolant pump
Attention!
Risk of damage:
Non-visible damage to the coolant pump.
Forcibly removing, installing or dropping the coolant pump down will damage it.
Remove and install the coolant pump without damaging it and without applying external force.
Avoid impacts/knocks to the coolant pump (e.g.. by tools, falling down, hard contact with base).
Necessarily renew the coolant pump after it falls or receives hard blows.
The damage is to the ECP plain journal bearings made of Graphitar graphite filled epoxy, soft and fragile, corrodes solid in a minute.
All of the BSD devices (IBS, alternator, OLCS, ECP, electric fan) are on individual lines to DME A6000.
Pulled the old water pump today as the replacement is due any minute from UPS... And it appears I had some serious corrosion on the and in the plug for the old unit... Cleaned it out with a copper brush and brake cleaner... Not certain it was causing my issue... But it couldn't of helped... Anyway at this point I'm still putting the new unit in!!
stabilant 22.. kinda pricey, but autobone even carries it. Works wonders on sketchy connections. Even better with a set of terminal cleaners. Diamond coated flat tweezer like tools.
I do alot of corrosion repair and these two are indispensable.
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
