The same brand and type you have on your front. You should not (in general) mix them unless you like quirky handling.Hey guys. I need to change rear tires of my 2002 330ci. What brand would you recommend?
Highly overrated advice.The same brand and type you have on your front. You should not (in general) mix them unless you like quirky handling.
^^^^^^^^Abso-Focking-Lutely.....on *dry pavement*, you can get away with running just about anything (different) on front & rear axles, but when the pavement is wet, that changes the whole game, and you`re literally taking your life in your hands.I totally disagree with the generalized advice that mixing is OK, and especially with the advice that rear tires don't matter as much as fronts. Much to the contrary, if you have grippy tires up front and cheap all-season high mileage tires in the rear, your chances of inducing unwanted oversteer (aka rear skid) in certain situations (especially wet) is very high.
Mixing Tires Article
Where to install new pairs of tires and why article
YSMV
If you have to throw in 'grippy', 'cheap' and 'different category' to pervert the original premise, I think you know you have a weak case.I totally disagree with the generalized advice that mixing is OK, and especially with the advice that rear tires don't matter as much as fronts. Much to the contrary, if you have grippy tires up front and cheap all-season high mileage tires in the rear, your chances of inducing unwanted oversteer (aka rear skid) in certain situations (especially wet) is very high.
