I was reading their FAQ and it's kind of wierd application process that they have. I am assuming you expert users can help me out.
For beginner you use Z1 or ZFX then on top of that you apply z2 or z5.
"Let Z-5 or Z-2 polish dry at least one hour. Please NOTE: Zaino Show Car Polish works best at 60 degrees or higher. However, it can be applied down to temperatures of 45 degrees. It just will take much, much longer to dry. As much as two to three hours drying time is required if the temperature is 50 degrees or below. Also, If the humidity is high. Longer drying time is necessary. Humidity is a killer on the drying time of Z-2 or Z-5"
-that is fine i wait about that long as well.
But the question is for those guys who has applied 7 or 8 layers
"After removal of Zaino Z-2 or Z-5. You should wait 24 hours if the outside temperature is under 70 degrees and 6 hours if over 70 degrees, before applying the next coat of Z-5 or Z-2."
Are you guys doing the multiple layers over a extended amount of period?? I am not sure if I am understanding the process very much.
I applied the second layer as soon as I was done with layer 1. Am i just wasting money???
