I'm about to replace the post-cat O2 sensors. No codes yet but at 162K miles I rather change them now, besides I will replace the giubo (flex disc) and center support bearing.
Pre-cat O2 sensors were changed when the car had about 108K miles
Sent from my MB860 using Bimmer App
Just installed 2 new 02 sensors today--the old ones had been in there for about 100k miles and when I took them out the tips were white-Is this bad and if so what could cause it--I researched and found that white tips could be from using nonsensor safe silicone gasket material. Well I thought that's all I ever have used on the car--could it be from the hoses that I am using for my oil catch can--They are fuel line hoses which I would think would be sensor safe--but heck you can't tell on everything
I replaced the Bosch with Denso 02 plugs this time--they cost a few dollars more--but from what I have read they react faster than the bosch--the but dyno says I like em--but I guess that time will tell when out on the road and the gas mileage records will prove or disprove what my feelings are about the new sensors--Ohh yeah, mileage on the car I bought new is now at 240k miles--
there is no sense to replace the post-cat O2 sensors unless you have a code. Pre-cat is a different story. DME does nothing with the post cat sensors for mixture, they will not effect performance/fuel economy. They are only used to monitor the cats. I would save the money for something else for now.
Doru try this
Update ECU & Reset engine adaption values
Update tranny software & Reset tranny adaptation values
See foam on a long drive in tank
+5% better gas mileage guaranty
With the new sensors installed--should I reset the adaptations?
Don't know how they will work in a month or two, but will be keeping an eye on what's happening and report back with findings
