Hi, recently purchased a very clean BMW 525i Sport E39 Touring. Its a 53 plate 2003 model.
I have had a few problems with the car and was hoping that someone may have had similar problems and would be able to advise or help.
I took the car for a drive the other day and noticed that when i have my air con off but the temp set to 16 on both sides the passanger side blows cold air but the driver side is warm or hot. Also there is very little coming out of the rear vents in the armrest.
I had the air con recharged today and it blows ice cold when air con is switched on but when its turned off the driver side gradually heats up.
Also I noticed smoke coming through the middle vents after I had been for a drive. Had a burning oil smell. Anyone know whats going on?. I thought it was oil leaking from the rocker cover gasket
I have just bought new discs and pads all round, air filter, pollen filters, fuel filter, oil filter, sump plug and seal, rocker cover gasket set with oil seal and 15 valve screw seals, also 8 litres of oil. So I am hoping to get all that stuff fitted over the weekend. The passanger side disc hex bolt is stuck though so its on hold until i get that free. The head is stripped.
Anything else i should be looking out for?. Really only the air vents that are bugging me. Read it could be fan clutch, or aux water valve/pump?. Any help would be much appreciated. Not looking to spend a fortune though as I just shelled out ££400 on all the parts and the air con recharge.
thanks
Paul
