1 - 7 of 7 Posts
joe
i have a 1993 bmw 325i and it had a bad heater hose and all the coolent came out and i had to put water in it well i messed up and went away for two years and the car just sat.... it froze and cracked the i know this because i can see the crack... so what my question is the car still runs and i put that bars leak fix in it so that i can drive it a little bit but now i want to fix it and my question is should i buy a head from a junk yard or should i find a hole motor for it??? does the block hold up good or do you think that it might be cracked to??
:dunno::bawling:
joe
Discussion Starter · #3 ·
the crack is in the head i can see it it goes the hole head also when driving it and i get out and open the hood the upper rad hose is hard and hot but the lower one is cold and also i open the res and coolent is cool the touch please i really need help because i really do love this car and want it to get fixed right with out breaking the bank
how do you see a hole in the head but still drive it?? :dunno:
this requires pics of said hole...:confused:
but if you are getting combustion pressures in the cooling system, then i suggest taking it apart to further inspect.
do you have vanos on the 93?? (never can remember when that started....)
if not, then it's even easier.
df
D'oh, You Kids!
1984 633CSi, 1985 635CSi, 1985 325e, 1987 325is, 1993 325is, 1995 318is, 1995 M3, 2003 F150
Yes, vanos started on the '93 YM. Got one. :D
We want pictures of the crack you can see.
A hot/pressurized upper hose and cold lower means the thermostat isn't opening or the radiator is clogged. DO NOT put Bars Leak in it.
Sometimes Out To Lunch!!!
:dunno::bawling:
Put as much BARS in it as you can, that will fix it alright........:rofl::rofl::rofl::rofl: Writing proper paragraph's would be a plus for you. Think about your ? so you don't ask stupid ones or sound stupid. Do a little searching also before you ask.:D Have a nice day
1 - 7 of 7 Posts
