Hey there, new guy here from the cold as hell northeastern part of Nevada in the USA.
As the title states, my door locks in my 89 535i are impossible to physically lock or unlock. I just got this car and I am new to BMW's in general, but I have done some reading about the central locking system that these cars have but no one seems to be having the same issue. It doesn't matter if I attempt to lock the driver or passenger door (or trunk) with the key, nothing happens. If I manually try to push down the locks, they will not budge. I honestly don't even know where to start, as I don't see a fuse or anything for the system.
Also, on an unrelated note: the dash is constantly saying some of my lights are out when they clearly are working just fine (I have read that this has to do with the CCM being bad) and the car keeps randomly throwing the dreaded Trans Program message but does not seem to go into limp mode as I can still manually shift and I can feel the car shifting through the gears as I drive. The only thing I have noticed is when that message pops up, the little "E" or "S" next to the gear indicator goes away. Someone definitely spilled some soda or something in the area where the gear shift is located (the Auto/Manual switch is stuck and won't even move), so I should probably clean all of that out. Also, the driver's window will not roll up using the switch unless I manually switch the polls on the back of the switch and use the "down" position to roll the window up. I have tried two master switches and got the same result.
Some details on the car:
1989 BMW 535i Sedan
4 Speed Automatic
278xxx Miles (Wow. I know.)
I paid $700 for it.
Runs okay, has some sort of slight misfire and definitely needs a tune-up, the transmission needs the fluid and filter changed and so does the differential. It sounds like crap when starting so I am thinking the starter may be going. Inside is pretty trashed, but the dash and upper door panels cleaned up nicely. Lower door panels and seats definitely need to be reupholstered or replaced. Overall I really like the car. It is definitely a new experience for me (I know how to work on cars, and I have had to do all the work myself on previous cars but this is going to be a whole new adventure for me). The fan doesn't wiggle, I don't smell coolant inside from the heater, no rear end noise. It does have an exhaust leak and a pretty bad lifter tick. The exterior of the car is okay, it's got some dents and all that but most things are intact. I think its the perfect candidate for a "Ballin on a budget" sort of build.
Thanks and I look forward to my time here and I am glad to meet everyone here on Bimmerfest.com.
1989 BMW 535i Sedan
4 Speed Automatic
I paid $700 for it.
