1 - 2 of 2 Posts
Alright so I got the OEM Carbon Fiber hood. On my old hood I would like to use the original window washer fluid hose and sprayers off of the hood... the problem is i have no idea how to take it off. The hose doesn't come off, there is no way to take off the clamp. So im out of ideas, can't take off the sprayers on the hood either. Do I have to buy another hose and window washer sprayer things? :mad:
i didnt find it too difficult to remove the hoses but you will need to dissconnect everything which is kind of a pain. i would recommend using metal hose clamps when putting everything back in. start by pulling the hoses from the dispensers. then dissconnect the t valve as it is too big to fit through anything. then just pull the hose from the front of the engine. from what i remember the toughest part is getting that t valve out. the dispensers should pop right out. i can be more specific is you run into certain problems. good luck
1 - 2 of 2 Posts
