1 - 8 of 8 Posts
Hi,
If I change my current rims (205/50 R17) to the 135M's 225/40 R18 front and 255/35 R18 rear, do I have to reset my speedometer?
I do'nt make mistakes.
carrollf said:
Hi,
No. Rim size isn't the issue: tire diameter basically the same for all stock sized rubber, so revolutions per mile remain the same.
You can look up the diameter for the tires you'll be putting on those new rims, and see what the % difference would be. I have a track wheel / tire setup that runs about 4% faster than the current ones, so 67.6 indicated mph is really 65 mph.
Indeed it is negligible.
JL
carrollf said:
Hi,
The difference between 205/50-17 and 225/40-18 is 0.1%. I think I've heard that up to almost 4.0% can be acceptable (although lower is better and I wouldn't go much beyond 1.0%).
Here's a tire size calculator for you to use, it's where I got my %s above...
http://www.powerdog.com/tiresize.cgi
Dragon Slayer
Interesting. My car came with 205/50/16, now I'm running 235/40/17 and my mph varies by 4-5 mph between my speedometer and GPS device I use. I wonder if the wheels caused the difference.
Though I sort of like my car overestimating my speed since it helps with speeding ... I think I'm going faster than I am. :D
Aren't BMW speedometers already off by 2MPH from the factory? When my odometer is reading 55, I am really only going 53. I have confirmed that with a GPS and one of those radars the cops set up on the side of the road to warn you about your speed. I would like to change my tire size to make it more accurate.
Tar Heel Faithful
I think it's a percentage error. At lower speeds, the difference is negligible, but at higher speeds it makes a difference. Unlocking your OBC helps you determine your actual real speed I believe......the digital readout in km/h is slower than what the analog speedo reads.
1 - 8 of 8 Posts
