1 - 6 of 6 Posts
Hi everyone,
New car new troubles :)
If this thread is in the wrong forum my apologies \ please move if necessary? If there is a thread for electrical please point me in that direction -
Car runs great but not sure if it is in tranport mode? or bigger electrical issues?
Have a Foxwell scanner and have cleared codes \ but not sure where or how to remove transport mode or determine if it is indeed in transport mode?
All fuses look good under passenger footwell. Is there another master fuse? or relay box somewhere? Battery was dead and has been replaced with new battery. I'm afraid the amp is fried as the battery compartment was full of water :-(
Current symptoms I'm chasing:
No interior lights
Door locks don't work
Windows don't work via interior button
remote key fob won't lock doors
Discussion Starter #4
Ok so fired up the Search function and looked at thread below mine.
Looking to install and use INPA for more information
https://www.bimmerforums.co.uk/threads/guide-installing-inpa-ediabas-on-windows-7-64bit.103023/
http://www.bimmerforums.com/forum/showthread.php?2125555-INPA-Delete-disable-Transport-Mode
https://www.bimmerfest.com/forums/showthread.php?t=1385637
The car had been sitting for over 2 years so a new battery was installed as the previous battery had died and the battery was completely submerged in water :-(
I have checked all the fuses with DVM for windows / door locks all check out with continuity test so I will continue to keep investigating
The AC blows but is not cold which will probably need a shot of refrigerant the light comes on when pressing the snowflake nob but I don't hear the compressor kick on which is probably due to low refrigerant oil.
1 - 6 of 6 Posts
