My 2008 750Li audio has stopped working no sound from radio or door chime, it want let me choose a radio station,cd,or auxiliary, and want pull up reverse sensor.
Hi, my car has no sound at all, no door chime, no warning sounds, no parking sensor tune, Navi, BT, Radio, CD are working fine, but no sound from navigation, I can pair my phone, I can make phonecall through the car, I have voice control, just doesn't have any sound. I can switch radio stations, I can use the Aux and USB.
All fuses are fine, I use Fiber Optic Loop to bypass TCU, AMP, Radio modules, nothing changed. All the fiber optic connectors have red light flashing when I unplugged them. But I found out that the AMP does not have output power(the 20 pins connect to the big harness of AMP, not sure how to describe it), so I bought one from eBay with exact same part number, put it in, leave the car on Ignition for a while, still no sound. I tried to disconnect the battery for an hour, nothing changed, I also reboot the iDrive by holding on the volume button.
I am out of ideas here, if anyone has the same problem, please please help, I really appreciate it! I just disconnected the battery for overnight, not sure it will fix it but I don't know what else to look. Looking forward to hearing your opinions, Thank you.
