Hi,
I would appreciate it if someone could help me with the issue. (E92 N55)
Day1:
Tried starting the car, no crank. The second time cranked and stared. (I thought I didn't push the button all the way)
Day5:
Got the car out of the airport parking lot, no start at all!
When I start the car, I hear a click but no crank. I hear something running too, I'm not sure if that's the started motor or fuel pump.
The thing that I've done so far:
1- The battery was half dead, so I took it to Autozone, charged for 2 hours, tested the battery --> Battery dead, Replaced the battery.
2- Disconnected IBS sensor --> No crank
3- Check the voltage at jump-start point <12V --> The positive battery is connected, no fuse blown at the battery
4- Connected jump-start negative to the engine block --> No crank --> Ground strap is fine
5- Check the Relays in Junction box(glove box) and E-box(under the hood) --> Works fine --> No failed relay
6- Check the fused in Junction box and E-box --> No blown fuse
7- Check the power cable at the starter --> The prob lights up --> Power at the starter
8- Checked the power at shiny copper terminal going from the solenoid to the started when trying to crank the engine ---> Prob doesn't light up --> (a)No commands to solenoid (b)Faulty started solenoid
So, My question is that how I can check to see if the command gets to the starter or not, before taking off the intake manifold to change the started. If I can check a positive signal to the starter while trying to start the car I can rule out CAS and DME faults. (I'm not sure which wire in E-box I should back prob to check it.)
Day1:
Day5:
