1 - 6 of 6 Posts
My dashboard lights don't work anymore. I replaced all the under the hood fuses having anything to do with the instrument cluster even though they all looked good.
I'll assume this was the cause: The same day they went out, my shifter knob loosened up and I pushed it back down. I shorted the wire going to the LEDs for the gear pattern against the shifter shaft. I've since repaired the wire.
Anyone know of any fuse wires in the circuit? I see reference to a remote fuse box under the LH side of the dash on the Z3 but I can't find anything on my 2000 M Roadster.
19,585 Miles
The fuse is the rheostat (variable resistor that controls the dimmed lighting) in the headlight switch.
Investigative Tinkerer
Sounds like you fried the rheostat in the headlight switch. Sorry.
I've done it too; it's possible to jump around the rheostat to get the lights back on (I always used them at full brightness anyway).
Edit: visual aid!
Old Timer
Thanks for posting that pic Randy! I just fixed mine tonite. The fix took 1min, putting the vent and switch back in took 30 mins. Not as bad as I thought, but very cramp area to work in.
1 - 6 of 6 Posts
