you are correct on the .55+/- .2, I just read about how to adjust for clearance on TIS.
Let me get something straight though, so when I am KOEO the fuel pump does not prime the fuel rail for 2-3 seconds like on a normal car? The crank sensor is indeed a magnetic pick up type and not a hell effect right? If this is the case how does the PCM know its at fault before it cranks and generates ac voltage? I know certain domestic vehicles will see proper hall effect voltage to start the pump but this is because the PCM supplies a reference and most likely a ground.
do these cars not prime the rail prior to KOEC? Mitchel has been less then helpful with circuit operations, i'll try all data tomorrow.
BTW if just because I have no posts on this forum it does not mean that I am new to using forums, it just shows I can search well... My unfamiliarity with German cars is really beating me over the head right now. I just hope this thing is a monster
