Got a 330i. While trying to accelerate into the freeway, seems the car won't getup and go. I pulled a p0741 torque converter before, but the check engine went away about a month ago. With this loss of power, anyone think it is the TQ?
Do you have the trans limp mode light on? It would be an exclamation point a gear around it and it shows up in your gear indicator screen. Like this....(see blue arrow)Got a 330i. While trying to accelerate into the freeway, seems the car won't getup and go. I pulled a p0741 torque converter before, but the check engine went away about a month ago. With this loss of power, anyone think it is the TQ?
Nope. That doesn't go on...Do you have the trans limp mode light on? It would be an exclamation point a gear around it and it shows up in your gear indicator screen. Like this....(see blue arrow)
Thanks I'll be sure to check that. I'm wondering if the Torque Converter could be stuck. Anyone have a similar issue with Torque Converters and lack of power. It's kinda like I'm in 5th gear and I'm trying to accelerate from 25mph. My car is an automatic.Check all vacuum hoses.
A small vacuum leak could be the cause of loss of power
