1 - 12 of 12 Posts
Hey everyone,
I updated my NBT EVO to 18-11-520 and after a couple days fighting to fix a problem injecting the correct CAFD (CdDeploy failed) I finally have it up and running again. Everything is working just as before except Satellite Radio.
When I select Satellite Radio it shows zero stations. It was working prior to flash and now the only difference I've seen is that the "Radio ID" is blank in the Subscription Option screen. All of the FSC codes are valid and accepted. Anyone have any ideas?
Premium Member
Check for Error Code 0xB7F8DC SDARS Transportmodus aktiv.
Discussion Starter #3
Hey Shawn, as always you're a wealth of information.
Looks like the first error. I have no idea how to get SDARS out of transport mode though.
Code:
// DTCList 7F: B7F8CD:2F,F8CD2F:B7,CD2FB7:F8,2FB7F8:5A,B7F85A:2F,F85A2F:B7,5A2FB7:F8,2FB7F8:B8,B7F8B8:2F,F8B82F:B7,B82FB7:F8,2FB7F8:C3,B7F8C3:28,F8C328:B7,C328B7:F8,28B7F8:C5,B7F8C5:28,F8C528:B7,C528B7:F8,28B7F8:1A,B7F81A:2F,F81A2F:B7,1A2FB7:F8,2FB7F8:DC,B7F8DC:2F,F8DC2F:B7,DC2FB7:F8,2FB7F8:F6,B7F8F6:2F,F8F62F:03,F62F03:17,2F0317:82
63->F4 59 02 7F B7 F8 CD 2F B7 F8 5A 2F B7 F8 B8 2F B7 F8 C3 28 B7 F8 C5 28 B7 F8 1A 2F B7 F8 DC 2F B7 F8 F6 2F 03 17 82 2F
Premium Member
Code:
It's not first one, but it is present:
DTCList 7F: B7F8CD:2F,F8CD2F:B7,CD2FB7:F8,2FB7F8:5A,B7F85A:2F,F85A2F:B7,5A2FB7:F8,2FB7F8:B8,B7F8B8:2F,F8B82F:B7,B82FB7:F8,2FB7F8:C3,B7F8C3:28,F8C328:B7,C328B7:F8,28B7F8:C5,B7F8C5:28,F8C528:B7,C528B7:F8,28B7F8:1A,B7F81A:2F,F81A2F:B7,1A2FB7:F8,2FB7F8:'DC,B7F8DC:2F,F8DC2F:B7,DC2FB7:F8,2FB7F8:F6,B7F8F6:2F,F8F62F:03,F62F03:17,2F0317:82
63->F4 59 02 7F B7 F8 CD 2F B7 F8 5A 2F B7 F8 B8 2F B7 F8 C3 28 B7 F8 C5 28 B7 F8 1A 2F B7 F8 DC 2F B7 F8 F6 2F 03 17 82 2F​
You can fix with ISTA or Tool32. PM sent.
Greetings Shawn, what were the steps to solve this. I am experiencing the same issue and my search brought me here. I have Tool32. Many thanks.
Premium Member
PM sent.
Hello all,
I'm also getting in ISTA: B7F8DC SDARS module not active
I don't need SDARS, as I'm located outside U.S.
How can I erase this fault ?
Premium Member
Remove 655 SATELLITE_TUNER from FA and VO Code Head Unit.
Thank you for prompt reply.
I double checked my FA, and I don't have 655 SATELLITE_TUNER.
However, I do have an accepted SDARS (006F0001) FSC code loaded in my Evo, which is generating this mismatch situation.
Maybe this fault in ISTA is expected, and can just be ignored ?
Premium Member
FSC code should not matter. This is EVO Head Unit?
Yes, it is a NBT2 EVO with I-Step 19-11.
I tried to set all FDL codes related to SDARS under HU_NBT2 ecu in E-sys to nicht_aktiv, however I still see this fault in ISTA.
Premium Member
PM sent.
1 - 12 of 12 Posts
