1 - 2 of 2 Posts
There is no spark on my 325i e36, i have replaced fuel pump and crank sensor, the engine turns but it doesn't run, could you help me guys to identify the problem.
D'oh, You Kids!
1984 633CSi, 1985 635CSi, 1985 325e, 1987 325is, 1993 325is, 1995 318is, 1995 M3, 2003 F150
Welcome to Bimmerfest!
Do you have fuel pressure at the rail after cranking? Will it fire on starter fluid (ether)? If it won't fire on starter fluid, the new crank position sensor may not be any good, or you have connection problems between the ECU (DME) and ignition.
Was the car running previously and quit, or has in never run while you've owned it? What year E36 is it?
1 - 2 of 2 Posts
