Still will not start-additional info. 318ti- '96
The fuel pump relay does not appear to have ground-that appears to be reason, I am only getting 5.5 volts. If I did a voltage test and do a chasis ground I get 12 v. I just found out this morning, that I have no spark. I put my OBII code reader in port and it will not communicate. Another observation, the battery symbol is continually illuminated, when turning over engine. Lastly there an idiot light illuminated above headlight switch. DME unit bad? Vehicle immobilization unit? Drivin Faster-hope you are on line.
